$1,995 ORDER NOW → |
$2,295 ORDER NOW → |
$3,195 ORDER NOW → |
$3,395 ORDER NOW → |
$6,995 ORDER NOW → |
| Shipping | |||||
| Shipping |
$149 via Ground to Contiguous USA International Available |
$249 via Ground to Contiguous USAInternational Available |
$349 via Ground to Contiguous USAInternational Available |
Freight Shipping to Contiguous USA with residential and liftgate options. |
| Cutting Area | |||||
| Cutting Area |
25” (X) x 23” (Y) x 3.0" (Z) |
25” (X) x 33” (Y) x 3.0" (Z) |
48” (X) x 33” (Y) x 3" (Z)+ (IHS) Initial Height Sensing |
48" x 48" (X & Y) x 3" (Z)+(IHS) Initial Height Sensing |
48" (X) x 96" (Y) x 2.5" (Z) |
| Support | |||||
| Support |
FREE LIFE TIME Phone and Email SUPPORT, Access to the online portal, and Forum |
Dedicated XR Support appointment system via phone, video, and email. Also includes Support Portal and Forum |
| Water Table | |||||
| Water Table |
Optional Stainless Steel Water Table |
Included 2 in Stainless Steel Water Table |
Included 3.5in Powder Coated Steel Water Table |
Included Reinforced Structural 65 Gallon Water Table |
| Torch Height Control | |||||
Manual Torch Height Adjustment, Optional Powered Z-Axis |
Powered Z Axis with Floating Head Hand Torch Mount with available Machine Torch Mount |
Powered Z Axis with Floating Head Machine Torch Mount |
| Initial Height Sensing | |||||
Available with Z-Axis Upgrade |
Included |
Included |
Included |
| Automatic THC | |||||
| Automatic THC |
Available Z-Axis & LS-THC Upgrade |
LS-THC Optional Add-On |
LS-THC Optional Add-on |
Included |
| Limit Switches | |||||
| Limit Switches |
Available Limit Switch Kit |
Included |
| Max Cut Speed | |||||
| Max Cut Speed |
300 IPM |
300 IPM |
300 IPM |
300 IPM |
400 IPM |
| Weight Capacity | |||||
| Weight Capacity |
1/2" Plate |
1/2" Plate |
1/2" Plate |
1" Plate |
1" Plate |
| Machine Weight | |||||
| Machine Weight |
130 LB |
130 LB |
223 LB |
290 LB |
750 LB |
| Machine Footprint | |||||
| Machine Footprint |
44.2" x 42.5" |
44.2" x 52.5" |
54.2" x 69.5" |
69” x 69.5” |
5.2' x 9.0' (6.6' x 11.3' with Mounted Touchscreen) |
| Gantry | |||||
| Gantry |
Cantilevered Gantry for ease of access |
Supported Gantry for extra stability |
Large Profile supported gantry beam with gusseted uprights |
| Drive System | |||||
| Drive System |
3/8”-8 4-Start ACME Lead Screws and Acetal Anti-Backlash Lead Nuts |
3/8”-8 4-Start ACME Lead Screws and Acetal Anti-Backlash Lead Nuts, 1/2” 5-Start Lead Screw (X) |
Upgraded 1/2”-8 4-Start ACME Lead Screws and Acetal Anti-Backlash Lead Nuts, 1/2” 5-Start Lead Screw (X) |
1/2" Ball Screws, Driven Rotating Ball Nut System |
| Motion Accuracy | |||||
| Motion Accuracy |
0.002" per 12" |
0.002" per 12" |
0.002" per 12" |
0.002" per 12" |
0.002" per 12" |
| Step Resolution | |||||
| Step Resolution |
0.0005" |
0.0005" |
0.0005" |
0.0005" |
0.0007” |
| Motion Controller | |||||
| Motion Controller |
LS Gen2 Motion Control |
LS XR Motion Control |
| Control Software | |||||
| Control Software |
FireControl |
FireControl |
FireControl |
FireControl (PRO MAX) |
FireControl XR with enhanced machine positioning, soft limits, and homing |
| Control Computer | |||||
| Control Computer |
Available Electronics Kit – 21.5" HD Touchscreen with Integrated Windows miniPC |
Included Electronics Kit – 21.5" HD Touchscreen with Integrated Windows miniPC |
| Torch Status LED | |||||
| Torch Status LED |
Unavailable |
Unavailable |
Unavailable |
Unavailable |
Included |
| Cable Management | |||||
| Cable Management |
Cable Support Tube |
Dual Drag Chain |
Langmuir Systems offers trusted CNC plasma cutting systems that include everything you need: a full cutting ecosystem with attentive Support, purpose-built Control Software, an engaged Community, and an active file Sharing Hub.
We offer systems small enough for your home garage and large enough for industrial shops all with the same interfaces, electronics, and software. You don’t have to learn a new workflow when your business grows.
Run your CrossFire with FireControl, our free machine controller software with tons of features that make cutting even easier. We’ve developed FireControl to be easy to use, efficient, and robust with features like: Pattern, Scale, Rotate, Run From line, Dry Run, and Straight Cut Generation. FireControl is Cross platform and runs on Windows and MacOS.
Explore FireControl →
Discover easy to cut projects for your shop, gifts for loved ones, and more on Langmuir Systems file sharing hub, FireShare. Upload your projects to share with others or download ready-to-cut files with custom parameters for your machine and material.
Explore FireShare →
Langmuir Systems Support Forum is a passionate group of over 5,000 CrossFire users with over 60,000 posts on over 4,000 topics. Ask a question, share your cool new project, or chat with other CrossFire customers.
Explore the Forum →
Ordering a CrossFire CNC Plasma table is easy. Here's what to expect once your order is placed.
