SMUDGE POT WASTE OIL BURNER Outdoor
outside Burn waste oil, diesel, kerosene, veggie oil. Add your fuel, open vents add a napkin inside the pot and light till burner starts. This is a repaired file from fireshare that was incorrect and not cut ready. This had been designed, cut and repaired and tested so it functions properly. you will need your own exhaust return pipe. we recommend stainless steel. we recommend spraying the unit with WD-40 before first burn to get good blue and gold finish affect. recommend cutting from cold rolled 16 guage steel or stainless for best finished results. you can bend the flu tabs inward for more vent flow if unit is snubbed out. YOU WILL NEED TO SCALE THIS DOWN .3 TO FIT A 4X8 TABLE AND CONNOT BE LESS THAN 23" WIDE PATTERN WIDTH
Creative Commons - Attribution - Non-Commercial - No Derivatives
You may download and share this work with others as long as you credit Brendan Conlon, but you can’t change it in any way or use it commercially.
4 months ago
83
  • BVC NORTH SMUDGE POT.nc
  • Brendan Conlon (OP) - 4 months ago
    credit to Dillon J Hart for the original creation.
    YOU WILL NEED TO SCALE THIS BY 0.85 TO FIT A 4 FOOT WIDE TABLE
  • Miles Fisch - 4 months ago
    Awesome design Brendan!!! Great Revisions, and a file that WORKS!!! :)
The License of this project does not allow derivative works or remixes.
