humming bird spinner actually cut ready Home & Garden
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Daniel for the original creation.
3 months ago
180
bird
  • humming bird spinner cut ready.dxf
  • Bret - 3 months ago
    You should give credit to Don P for this design. https://www.langmuirsystems.com/fireshare/spinning-hummingbird
    Daniel (OP) - 3 months ago
    When i went to post it would give an error when i pasted the link.
    But also it has been up for 2 years with a flawed dxf file that could not be immediately used as can be seen in its comments
    Bret - 3 months ago
    There is an option to post it as a "Remix". That gives a shoutout to the original poster when you make upgrades. I'm not trying to be critical of you. I've upgraded and reposted the work of others myself. It's helpful and most who give away designs here have no issue with it.
  • James Mersereau - 2 months ago
    Thanks for cleaning up the errors. Side note: on this site "CUT READY" does not mean that the DXF is free of errors, it means that the post processing has been done and is now a TAP, NC or other gcode format file.
