Press Break Stackable Dies Tools
I tried to include as much about each die as I could on the file names. All files are standard .5" chuck size. Feel free to cut out of any size metal (the thicker the better). I often cut these out of left over steel and stack them to make full die widths or for custom needed bends.
4 months ago
74
die tool langmuir
  • 2 inch wide 90 deg upper die SP-2000A.dxf
  • 2.5 inch wide 85 deg lower die SD-2000A.dxf
  • 3.25 inch wide 90 deg lower die SD-2500A.dxf
  • 2 inch wide 85 deg lower die SD-1500A.dxf
  • 1.5 inch wide 90 deg lower die SD-1125A.dxf
  • 1.25 inch wide 90 deg upper die SP-1125A.dxf
  • 1.5 inch wide 30 deg upper die SAP-3.dxf
  • 2 inch wide 32 deg lower die SAD-875.dxf
  • 1.25 inch wide 28 deg upper die SAP-2.dxf
  • 1 inch wide 28 deg upper die SAP-1.dxf
  • 1 inch wide 30 deg lower die SAD-250 - 22 gauge.dxf
  • 1 inch wide 30 deg lower die SAD-375 - 20 and 18 gauge.dxf
  • 1 inch wide 30 deg lower die SAD-500 - 16 gauge.dxf
  • jon sampson - 4 months ago
    very nice
    Zeke Church (OP) - 3 months ago
    Thank you! I have made ALOT now with all the small left over scrap laying around! Happy Cutting!
  • Rico - 2 months ago
    Excellent idea!
