Apollo 4 Assembly Guide
Last updated: Nov 13, 2026
Print
Safety
When used correctly, your Langmuir Systems Apollo 4 CNC fiber laser will give you years of safe operation. Like all automated industrial machinery, it has hazards that can cause serious injury or death if the precautions in this section are not followed.
Read this section and the safety labels on the machine before you assemble or use your Apollo 4. Keep this guide with the machine and make sure everyone who operates or services it has read it.
Warning
LASER HAZARDS
Class 4 laser radiation
The Apollo 4 contains a Class 4 fiber laser (max output 1500 W, continuous wave, 1064–1080 nm). The beam is invisible, and direct or scattered radiation can cause permanent blindness and severe burns.
To avoid injury, always adhere to the following precautions:
  • Wear laser eyewear OD 8+ at 1064–1080 nm whenever the laser is on. Ordinary safety glasses give no protection.
  • The enclosure does not block laser radiation. Keep all panels in place and never defeat or remove the safety switches.
  • Turn off the laser source before retrieving parts or servicing the nozzle or lens. Never look into the nozzle.
  • Set up a designated laser area with a warning sign at each entrance, and alert bystanders before cutting.
  • Wear gloves and clothing that cover your skin.
ELECTRICAL HAZARDS
ELECTRICAL HAZARDS
Electric shock and arc flash
The Apollo 4 and its water chiller run on 220–240 VAC. Electric shock or an arc flash can cause severe burns or death, and capacitors hold dangerous voltage after power is off.
  • Never touch live wires, terminals or components. Never work on energized equipment.
  • Only qualified persons may open the electronics box. Lock out power first.
  • Wait at least 5 minutes after power off, then verify zero voltage before touching components.
  • The chiller has its own 18 A supply. Lock it out separately before servicing.
Fire
FIRE, GAS AND FUMES
Fire
Sparks, molten slag and hot parts from laser cutting can ignite nearby flammable materials. Oxygen assist gas makes materials burn faster.
  • Never leave the machine unattended while cutting.
  • Keep slag and scrap cleared from the cutting bed and slag tray.
  • Never operate near flammable materials and never cut containers that have held fuel or any flammable substance.
  • Always keep a fire extinguisher near the machine.
  • Aluminum and titanium dust is combustible. Empty the dust collector regularly and use one rated for combustible metal dust.
Gas explosion
FIRE, GAS AND FUMES
Gas explosion
Pressurized oxygen and nitrogen can burst fittings and cause an explosion or fire, resulting in severe burns or death. Nitrogen can displace oxygen and cause suffocation. Oxygen makes oil and grease ignite easily.
  • Use clean, dry, industrial-grade gas and a regulator rated for each gas. Never exceed O2 80 PSI (5.5 bar) or N2 190 PSI (13.1 bar).
  • Connect each gas only to its labeled inlet, and keep oxygen fittings, lines and hands free of oil and grease.
  • Secure gas cylinders upright with a chain or bracket, away from heat and sparks.
  • Close the supply valves when not in use and bleed the lines before disconnecting anything.
  • Check for leaks with leak-detection solution.
warn-radiations
FIRE, GAS AND FUMES
Hazardous fumes and ventilation
Laser cutting produces fumes and fine metal dust that can cause respiratory irritation, lung damage or metal fume fever. Ventilation is always required.
  • Run fume extraction for every cut, especially aluminum, stainless steel, brass, copper and galvanized or coated metals.
  • Connect the fume extractor before cutting and vent it outdoors. Never cut with the blower off or the enclosure open.
  • Never cut material coated with paint, oil, grease or solvents, or PVC and other plastics containing chlorine.
  • Check the Safety Data Sheet (SDS) for each material to learn what fumes it produces.
  • If ventilation is poor, use an air-supplied respirator.
MOVING PARTS AND HEAT
Pinch and crush points
The gantry and cutting head move quickly and with force and can start moving without warning whenever the machine is powered.
  • Keep hands clear of the moving gantry and never reach into its path while the machine is powered.
  • Lock out power before servicing, cleaning or adjusting anything in the cutting area.
  • During assembly, keep hands out of crush points and watch for pinch points at nested flanges, hinges and attachment areas.
  • Use two people to lift and position heavy panels and assemblies.
Hot surfaces
Hot surfaces
Cut parts, slats, slag and surfaces in the cutting area stay hot enough to cause severe burns after cutting.
  • Always assume metal on or in the machine is hot enough to cause severe burns.
  • Allow parts, slats and surfaces to cool before handling.
  • Never handle hot metal with bare hands. Use heat-resistant gloves or tongs.
Lockout
SERVICE
Lockout / tagout
A machine that is only switched off can be restarted by someone else. Before servicing, cleaning or repairing the Apollo 4, lock out all three energy sources:
E-1 Main electronics
220–240 VAC, 20 A
E-2 Water chiller
220–240 VAC, 18 A
G-1 Assist gas
O2 80 PSI, N2 190 PSI
  1. Tell anyone affected, stop the machine normally and turn off the laser source.
  2. Turn off or unplug E-1 and E-2 and apply your lock and tag to each.
  3. Close the G-1 gas valves, apply a valve lockout and tag, and bleed the lines.
  4. Wait 5 minutes, then verify: the machine will not start, the chiller is off and the gas gauges read 0 PSI.
  5. When work is complete, reinstall all guards and panels, then remove locks and tags.
GENERAL
GENERAL
Do not enter the cutting area
The gantry can move without warning whenever the machine is powered and can crush or trap you. Nitrogen assist gas can collect in the cutting area and cause unconsciousness or death without warning. Oxygen assist gas makes clothing and hair burn easily.
  • Never climb into, crawl into or lean your body inside the cutting area.
  • Retrieve parts and scrap from outside the machine using a hook, tongs or other reach tool.
  • If a part cannot be reached, lock out all energy sources before reaching in.
WARNING
California Prop 65
Risk of cancer and reproductive harm from exposure to lead. See www.P65Warnings.ca.gov.
  • Lead is present in solder used in the machine's electrical components.
  • Wash your hands after handling wiring or electrical components.
SAFETY
Handling the fiber cable and optics
Warning: a kinked fiber cable or a scratched lens cannot be repaired, only replaced.*
Clean work area
Clean work area
Do: Dust-free, dry space; caps on until install.
Don't: Grind or cut metal near open optics.
Yellow fiber cable
Yellow fiber cable
Do: Leave as shipped; support it when moving the head.
Don't: Pull, pinch, step on or unplug it.
Bend radius
Bend radius
Do: Bend the yellow cable in wide curves, 150–200 mm min.¹
Don't: Kink, coil tightly or zip-tie it.
Holding the lens
Holding the lens
Do: Wear nitrile gloves; hold optics by the edges.
Don't: Touch surfaces or set a lens face-down.
Cleaning the lens
Cleaning the lens
Do: Lens tissue, 99% isopropyl, one wipe.
Don't: Breathe on it or wipe with fingers or cloth.
Consumable life
Consumable life
Do: Check the window before each job; replace if cloudy.
Don't: Leave residue; the laser bakes it into the glass.
¹ Yellow fiber cable only. Typical for armored laser cables (15–20× outer diameter). Source: YH Laser, 2026.
* Damage caused by handling outside these guidelines may not be covered under warranty.
0: Unboxing
The Apollo 4 is delivered on a single pallet with all components packed and labeled. The next pages list every box on the pallet and what is inside it. Use them as a reference throughout the assembly.
PALLET CONTENTS
Sub Box 1 and Sub Box 2
SUB BOX 1 Frame
  • Gantry Tube ×1
  • Leg Tube ×2
  • Leg Tube, Mirrored ×2
  • Lower Cross Tube ×2
  • 4X4 Y Axis Rail ×2
  • 4X4 LH Lower Rail ×1
  • 4X4 RH Lower Rail ×1
  • Lead Screw X Axis (1/2") ×1
  • 4X4 Y Axis Lead Screw (1/2") ×2
SUB BOX 2 Long Channels & Supports
  • Upper Brace Assembly×1
  • Upper Gusset Assembly×4
  • Upper Y-axis Support Assembly×2
  • Upper X-axis Support Assembly, Front×1
  • Upper X-axis Support Assembly, Rear×1
  • C Channel Front Door×2
  • Rear Panel Flap×1
  • Y-axis Cable Chain Tray×1
  • X-axis Cable Chain Tray×1
  • Cutting Bed Mount×1
  • Bed Side Mount×2
PALLET CONTENTS
Sub Box 3: Mounts
SUB BOX 3 Mounts
  • Enclosure Mount Assembly ×2
  • Narrow Enclosure Mount Assembly×2
  • Door Switch Plate Assembly ×1
  • Steel Stanchion Plates ×8
  • Leveling Foot Base ×10
  • Source Foot ×1
  • Source Tab ×1
  • Tab A ×1
  • Tab B ×1
SUB BOX 3 Mounts (continued)
  • Chain Tab Weldment×1
  • X-axis Chain Tab×2
  • Chain Tower Weldment×1
  • Slat Mount×4
  • Motor Cover×1
  • Laptop Angle Mount Weldment×1
  • Laptop Stand Weldment×1
  • Tray, Laptop Stand×1
  • Front Mounting×2
PALLET CONTENTS
Sub Boxes 4, 5 and 6
SUB BOX 4 Electronics Box
  • Electronics Box (complete unit) ×1
SUB BOX 5 Gas Box
  • Gas Box (complete unit) ×1
SUB BOX 6 Gantry Components & Hardware
  • CBox 6.1: Z-axis Assembly
  • Carriage Weldment
  • Laser Head Mounting Plate
  • Box 6.2: Hardware Box
  • Box 6.3: Miscellaneous Box
PALLET CONTENTS
Loose items on the pallet
BUNDLE 1 Corners
  • Corner, Narrow Front Assembly ×1
  • Corner, Narrow Rear Assembly×1
  • Corner, Rear Assembly ×1
  • Corner, Front Assembly ×1
BUNDLE 2 Corner Gussets
  • Corner Gusset ×3
  • Corner Gusset Mirrored ×3
SEPARATE Packed Separately
  • Drag Chain ×2
  • Source & Laser Head Box ×1
  • Chiller Box ×1
BUNDLE 3 Chiller Side Right
  • Smooth Side ×1
  • Smooth Side 2 ×1
  • Door ×2
PALLET Bottom of the pallet
  • Slat ×15
  • Slat Holder ×2
  • Smooth Roof Sheet ×2
  • Cutting Bed Front ×1
  • Cutting Bed Extension ×1
BUNDLE 4 Chiller Side Left
  • Bed Side A ×1
  • Bed Side B ×1
  • Cutting Bed Bottom ×1
  • Shielding Plate ×1
  • Rear Panel ×1
  • Rear Bottom Enclosure Panel ×1
  • Front Upper ×1
  • Front Alt Lower ×1
