introduction-banner
CNC Plasma and Fabrication Tools for Your Home Garage
Turn weekend projects into finished metal parts. Langmuir Systems builds CNC plasma tables, mills, press brakes, weld tables, and powder coat ovens sized for a home garage, so you can design it, cut it, and build it yourself.
Crossfire PRO MAX
Build It in Your Garage
Stop buying parts that almost fit. With a CNC plasma table in your garage, you draw a bracket, sign, or mount on your computer and cut it from steel the same afternoon.
Start with a benchtop CrossFire, then add bending, welding, and finishing as your projects grow. Plan your layout with our Interactive Shop Planner.
Will It Fit in My Garage?
Most home garages already have what a CrossFire needs. Check these four things before you order.
Power
CrossFire tables run on a standard 120V outlet. Your plasma cutter is the bigger load, and most reach full output on a 240V circuit. Have an electrician check your panel if you don't have one.
See plasma cutters →
Space
The CrossFire cuts 2' x 2' on a sturdy base, the CrossFire XL cuts 2' x 3', and the CrossFire PRO cuts 4' x 3'. Leave room to load sheets and walk around the machine.
Lay out your garage →
Compressed Air
Plasma cutters need clean, dry air. The Razorcut 45 needs 6.7 CFM at 75 psi, so size your compressor above that and add a filter or dryer.
Compare cutter air needs →
Fumes and Safety
The water table catches sparks and traps dust. Cut with the garage door open, add a fan, wear plasma-rated eye protection, and keep flammables away from the machine.
Your Garage Shop Lineup
CUTTING
CrossFire
CrossFire
CrossFire PRO MAX
CrossFire PRO MAX
MILLING
MR-1
MR-1
BENDING
Titan 25T
Titan 25T
WELDING
ArcFlat
ArcFlat
FINISHING
Vulcan 16
Vulcan 16
Crossfire
CrossFire CNC Plasma Table, Built for the Home Garage
Cut brackets, signs, fire pit rings and truck parts on a benchtop table that plugs into a standard 120V outlet. Need more room? The CrossFire XL cuts 2' x 3' and the CrossFire PRO cuts 4' x 3'. Starting at $1,995.
Learn More
First Projects for Your CrossFire
Start with a file someone else already proved, then make it your own. Every idea below has ready-to-cut designs on FireShare.
Brackets and Mounts
Light mounts, shelf brackets, bike racks, and tool hangers. Simple shapes in 1/8" to 3/16" steel are the fastest way to learn your machine.
Find brackets on FireShare →
Signs and Wall Art
House numbers, shop signs, and silhouettes. Cut detail in thin steel, then powder coat it for outdoor use.
Find signs on FireShare →
Fire Pit Rings
Cut decorative panels and roll them into a ring, or bolt flat panels into a square pit.
Find fire pits on FireShare →
Truck and Jeep Accessories
Light bars, license plate relocators, recovery points, and interior brackets for your own rig.
Find accessories on FireShare →
Shop Organization
Wrench racks, welding cart parts, clamp holders, and wall-mount tool storage for your own garage.
Find shop projects on FireShare →
Gifts and Small Sales
Coat hooks, bottle openers, and custom name signs. Many owners sell them online or at markets to pay off their machine.
Browse FireShare →
Crossfire Pro Max
CrossFire PRO MAX, Your Next Step Up
Ready for bigger projects? CrossFire PRO MAX cuts a true 4' x 4' sheet and handles plate up to 1" with a larger plasma cutter. Already own a CrossFire PRO? The PRO MAX Upgrade Kit ($999) converts it. Starting at $3,395.
Learn More
What CrossFire PRO MAX Adds to Your Garage
more cutting area
Room for Bigger Projects
A true 48" x 48" cutting area fits gates, large signs and full fire pit panels in one setup.
Crossfire PRO MAX
Thicker Steel When You Need It
Pair it with a bigger plasma cutter to cut plate up to 1" thick for trailer and heavy project parts.
Automatic torch height control
Cleaner Cuts on Warped Sheet
Works with Langmuir's automatic torch height control, which raises and lowers the torch as it cuts.
promax-8
Upgrade Your CrossFire PRO
The PRO MAX Upgrade Kit adds a larger table, deeper water pan and heavier lead screws to the PRO you already own.
1 / 1
Not Sure Which CrossFire Fits?
Compare every CrossFire side by side, from the 2' x 2' CrossFire to the 4' x 8' CrossFire XR, on our CNC Plasma Tables page.
AFFORDABLE CNC MILLING IS HERE
MR-1 CNC Gantry Mill, Real Machining in a Home Shop
Machine aluminum and steel parts your plasma table can't: threaded holes, precise bores, and 3D shapes. MR-1 was designed for hobbyists and small shops, removes up to 30 pounds of steel per hour, and starts at $5,195.
Learn More
What MR-1 Adds to Your Garage
Drill Big Holes Easily
160 lb of Z-axis thrust and up to 9" under the spindle let you use full-length drills in steel and aluminum.
Threads Without Hand Tapping
Mill custom threads with a single tool, faster than tapping by hand and more accurate.
Faster Setups
Add the Touch Probe and Tool Setter to find your part automatically and change tools in seconds. Both plug right into the MR-1.
1 / 1
Titan 25t
Titan 25T CNC Press Brake, Clean Bends at Home
Bend the brackets, boxes, and tabs you cut on your CrossFire with crisp, repeatable angles. Titan 25T arrives fully assembled, programs on its own touchscreen, and starts at $4,995.
Learn More
What Titan 25T Adds to Your Garage
industrial compact size
Arrives Fully Assembled
The base machine shows up ready to bend. Unpack it, program a part and start bending. Some add-ons need assembly.
EXTERNAL SOFTWARE NEEDED
No Computer Required
Program bends on the built-in touchscreen with BendControl's conversational programming, or run it fully manual.
SERIOUS BUDGET TOOLING
Affordable Tooling
Our catalog of punches and dies covers the bends most home projects need, at hobby-friendly prices.
1 / 1
ARCFLAT
ArcFlat Weld Table, a Pro Weld Table for Your Garage
Clamp, square, and weld your projects on a precision cast iron surface instead of the garage floor. Each 2' x 3' ArcFlat Weld Table block has 336 fixture holes, ships ground to your door, and bolts to more blocks as you grow. Starting at $775.
Learn More
What ArcFlat Adds to Your Garage
NO ASSEMBLY NO HASSLES
No Assembly, No Welding
ArcFlat ships by standard ground right to your door. No weld-it-yourself tab and slot table to build first.
Modular to fit your needs
Start Small, Add On Later
Use one 2' x 3' block in a small garage, then bolt on more blocks when you need a bigger table.
Clamp Anywhere
336 holes on the top and sides fit Langmuir modular clamps or any 5/8" or 16mm tooling.
1 / 1
Configure Your ArcFlat
Check out the 2, 3, and 4 block workbench configurations that fit a home garage.
1. Select ArcFlat Table Qty
2. Table Layout Shape
3. Add Additional Leg Kits for Heavy Duty Use
3
Interactive Surface Layout
108" WIDE
72" DEEP
CUTOUTS: 36" x 24" (LEFT & RIGHT)
Recommended Components
  • ArcFlat Weld Table - $775 Each 24"x36" Cast Iron Weld Block.
    5
  • ArcFlat Leg Kit - $95 Each 4 Steel tube legs with leveling feet.
    3
  • Precision Leveling Bolt Kit - $35 Each Joins 2 blocks together while maintaining flatness.
    4
  • Multi-Block Savings -$200
Total: $4,000
Vulcan 16
Vulcan 16 Powder Coat Oven, a Pro Finish at Home
Give your projects a tough, colorful finish without paying a coater. Vulcan 16 fits in a garage, cures parts evenly, and runs on CureControl software. Starting at $1,499.
Learn More
What Vulcan 16 Adds to Your Garage
Precision Digital Controls
Simple Digital Controls
Set the cure temperature and time on CureControl and let the oven hold it. No guesswork, no kitchen oven.
Durable Construction
Insulated to Save Energy
Mineral wool insulation keeps heat inside the oven, not in your garage.
customization at your fingertips
Add What You Need
Customize your Vulcan 16 with add-ons as your powder coating projects grow.
1 / 1
Home Garage FAQ
Can I run a CNC plasma table on 120V power?
Yes. CrossFire tables plug into a standard 120V outlet. Your plasma cutter is a separate load, and most reach full output on a 240V circuit, so check your plasma cutter's power needs before you buy.
How much space does a garage CNC plasma table need?
The CrossFire cuts 2' x 2' and sits on a sturdy base. The CrossFire XL cuts 2' x 3' and the CrossFire PRO cuts 4' x 3'. Leave room to load sheets and walk around the machine, and use our Interactive Shop Planner to lay it out.
Is CNC plasma cutting hard to learn?
Most owners start by cutting a ready-made file from FireShare, which separates learning the machine from learning design. FireControl software is free, and the Langmuir forum and support team help when you get stuck.
How much does a home garage CNC plasma setup cost?
A CrossFire with a Razorcut 45 plasma cutter starts at about $3,284 before shipping and tax. You'll also need an air compressor and safety gear if you don't already have them.
Can I make money with a hobby CNC plasma table?
Many owners sell signs, gifts and custom parts to pay off their machine. FireShare files are free and commercially licensed, so you can sell what you cut from them.
What should I cut first?
Start with a simple bracket or sign from FireShare in thin steel. It lets you dial in cut speed and height before you design your own parts.
Start Building in Your Garage
Pick your first CrossFire, plan your space, or ask thousands of owners what they'd do. Building small projects for sale? See Art and Metal Sign Making. Building auto or off-road parts for customers? See Automotive Fabrication. Running a job shop? See Metal Fabrication.
