Every accurate weldment starts with a flat, square surface.
Every accurate weldment starts with a flat, square surface, so choosing a welding table is one of the most important decisions in a fabrication shop. Most fabricators choose between three options: a pre-machined cast iron fixture table like the Langmuir Systems ArcFlat, a tab-and-slot steel kit you weld yourself, or a traditional welded steel table built from scratch. The right choice comes down to precision, setup time, material properties, and total cost, including your time.
Flatness and accuracy. Your parts can only be as square as the surface you build them on. Fit-up accuracy is critical for fixtures, frames, chassis work, and repeat parts, so start with a table that's already flat rather than one you hope comes out flat.
Setup time. A machined table is ready the day it arrives. A tab-and-slot kit can take hours to a full weekend of clamping, tacking, and welding. A scratch-built table takes longer still. If your shop time is billable, count those hours as part of the price.
Hole pattern and clamp compatibility. Most fixture tables use 5/8" or 16mm holes on a grid, which work with standard third-party clamps and fixtures. Check hole size and spacing before you buy so your clamps fit across your whole shop.
Size and expandability. Buy for the work you do today, but plan for the work you'll take on next. Modular tables let you start small and add surface area later without rebuilding. See which size fits your work →
Load capacity and durability. Consider the heaviest parts you'll fixture and how you work. Steel tolerates hammer blows by bending. Cast iron stays flat under heavy loads and resists spatter, but it can crack under extreme point impacts.
Total cost. Add up the table, legs, clamps, and the hours spent building, flattening, or grinding. The cheapest option on paper isn't always the cheapest once it's in use.
Size your table for the parts you build most often, with room around them for clamps. Because ArcFlat blocks bolt together, you can start with one and grow.
Fits brackets, small frames, jigs, and bench-size parts. A good starting point for a garage or a first fixture table.
Bolt two blocks end to end for long parts like rails and trailer tongues, or side by side for a deeper surface for frames and gates.
Build larger surfaces for chassis, gates, and long assemblies. The configurator plans layouts with up to seven blocks.
Size for your typical part plus a few inches on every side for clamps, stops, and squares. If you're between sizes, start smaller and add a block later.
The ArcFlat is a pre-machined, modular welding and fixture table crafted from a thick block of nodular cast iron.
These popular DIY kits use laser-cut steel plates that fit together like puzzle pieces. You lock them in place with tabs and slots, then weld them into a finished table.
These are tables built completely from scratch using thick steel plates, angle iron, and square tubing.
Choose the ArcFlat if… you need accurate reference surfaces right away, do repeat or precision fixture work, or would rather spend shop time on paying jobs than on building a table. It's the fastest path from delivery to welding.
Choose a tab-and-slot kit if… your budget comes first, you have time to build carefully, and you're comfortable correcting some distortion. It's a solid upgrade over a bench or a scrap-plate top.
Choose a welded steel table if… you need an unusual size, height, or capacity that no off-the-shelf table offers, and you have the materials, tools, and time to build and flatten it yourself.
| ArcFlat | Tab-and-Slot | Welded Steel | |
| Material | Solid Nodular Cast Iron | Hot-Rolled Steel Plate (e.g., A36) | Steel Plate, Tubing, and Angle Iron |
| Manufacturing | CNC-machined from a single block (top and 4 sides) | Laser-cut interlocking steel kits | Fabricated entirely by hand |
| Surface Flatness | Machined to ±0.0075" | Depends entirely on assembly/welding skill | Depends heavily on fabrication skill & warping |
| Squareness | Sides machined square to 0.1° | Depends on fit-up | Depends on fabrication |
| Assembly Effort | None (bolt-on legs, ready out of the box) | High (puzzle-piece fit, requires extensive clamping and tacking) | High (cutting, squaring, fitting, and welding from scratch) |
| Warp Risk | None (No weld distortion during assembly) | Moderate to High (heat from welding slots can distort plate) | High (welding a frame/top inevitably introduces pull and warp) |
| Hole pattern | 2" x 2" grid, 336 holes per block | Grid pattern, varies by kit | None, unless you drill or cut them |
| Clamp compatibility | Standard 5/8" and 16mm clamps | Usually 5/8" or 16mm, varies by kit | Edge clamps only, unless drilled |
| Load capacity | 1,000 lbs static per block | Varies by kit and build | Varies by design |
| Spatter Resistance | Good (cast iron naturally sheds spatter well) | Moderate (requires anti-spatter spray) | Moderate (requires anti-spatter spray) |
| Modularity | High (precision-machined to bolt multiple units together) | Varies (some kits allow linking, others are standalone) | Low (fixed design unless custom-engineered) |
| Upfront cost | $775 per block | Lower upfront; plus your build time | Lowest material cost; highest time cost |
A fixture table is only as useful as the clamps you put in it. Here's what to know before you buy.
These are the two common fixture-table standards, and they're close enough that many clamps fit both. The ArcFlat's 0.630" holes accept standard 5/8" and 16mm clamps.
A few hole-mounted clamps that push straight down cover most fit-up jobs. Add more as you take on bigger parts.
Stops and 90° squares in the hole grid let you set up repeat parts in seconds and keep every piece in the same spot.
ArcFlat's machined side faces have tooling holes, so you can clamp vertically, build up off the edge, or bolt blocks together.
It depends on your work. Cast iron can be machined very flat, resists warping, and sheds spatter well, which makes it ideal for precision fixturing. Steel is tougher under hard impacts and costs less upfront, but it's harder to keep flat once welded. For accurate fit-up out of the box, cast iron has the edge.
They can. Welding the internal ribs and slots puts a lot of heat into the structure, and that heat can pull the top out of flat. Careful clamping, a planned weld sequence, and stitch welding reduce distortion, but the final flatness depends on the builder.
Clamps and fixtures designed for 5/8" (16mm) fixture-table systems. The ArcFlat's 0.630" holes accept standard third-party 5/8" and 16mm clamps, and Langmuir Systems offers ArcFlat clamp and fixture accessories as well.
Size it for your typical part, plus room for clamps and fixtures around it. A single 36" x 24" ArcFlat block suits brackets, small frames, and bench work. Bolting blocks together creates larger surfaces for chassis, gates, and long assemblies.
Yes. Every ArcFlat block is precision-machined to bolt to others, so you can start with one block and add more as your work grows. The configurator lets you plan layouts with up to seven blocks, and you can build tables as large as you need to support your shop.
No. It arrives fully machined and ready to use. Just bolt on the optional legs, or set it on your existing bench.
For precision fixturing, look for a top machined flat to within a few thousandths of an inch. The ArcFlat is machined to ±0.0075", while a welded steel top can be off by much more once the frame is welded underneath.
Both systems are nearly the same size, and many clamps work in either. The ArcFlat's 0.630" holes accept standard 5/8" and 16mm clamps, so you aren't locked into one brand.
