California Prop 65
Risk of cancer and reproductive harm from exposure to lead. See www.P65Warnings.ca.gov.- Lead is present in solder used in the machine's electrical components.
- Wash your hands after handling wiring or electrical components.
When used correctly, your Langmuir Systems Apollo 4 CNC fiber laser will give you years of safe operation. Like all automated industrial machinery, it has hazards that can cause serious injury or death if the precautions in this section are not followed.
Read this section and the safety labels on the machine before you assemble or use your Apollo 4. Keep this guide with the machine and make sure everyone who operates or services it has read it.
The Apollo 4 contains a Class 4 fiber laser (max output 1500 W, continuous wave, 1064–1080 nm). The beam is invisible, and direct or scattered radiation can cause permanent blindness and severe burns.
To avoid injury, always adhere to the following precautions:
The Apollo 4 and its water chiller run on 220–240 VAC. Electric shock or an arc flash can cause severe burns or death, and capacitors hold dangerous voltage after power is off.
Sparks, molten slag and hot parts from laser cutting can ignite nearby flammable materials. Oxygen assist gas makes materials burn faster.
Pressurized oxygen and nitrogen can burst fittings and cause an explosion or fire, resulting in severe burns or death. Nitrogen can displace oxygen and cause suffocation. Oxygen makes oil and grease ignite easily.
Laser cutting produces fumes and fine metal dust that can cause respiratory irritation, lung damage or metal fume fever. Ventilation is always required.
The gantry and cutting head move quickly and with force and can start moving without warning whenever the machine is powered.
Cut parts, slats, slag and surfaces in the cutting area stay hot enough to cause severe burns after cutting.
A machine that is only switched off can be restarted by someone else. Before servicing, cleaning or repairing the Apollo 4, lock out all three energy sources:
220–240 VAC, 20 A
220–240 VAC, 18 A
O2 80 PSI, N2 190 PSI
The gantry can move without warning whenever the machine is powered and can crush or trap you. Nitrogen assist gas can collect in the cutting area and cause unconsciousness or death without warning. Oxygen assist gas makes clothing and hair burn easily.
California Prop 65
Risk of cancer and reproductive harm from exposure to lead. See www.P65Warnings.ca.gov.Warning: a kinked fiber cable or a scratched lens cannot be repaired, only replaced.*
Do: Dust-free, dry space; caps on until install.
Don't: Grind or cut metal near open optics.
Do: Leave as shipped; support it when moving the head.
Don't: Pull, pinch, step on or unplug it.
Do: Bend the yellow cable in wide curves, 150–200 mm min.¹
Don't: Kink, coil tightly or zip-tie it.
Do: Wear nitrile gloves; hold optics by the edges.
Don't: Touch surfaces or set a lens face-down.
Do: Lens tissue, 99% isopropyl, one wipe.
Don't: Breathe on it or wipe with fingers or cloth.
Do: Check the window before each job; replace if cloudy.
Don't: Leave residue; the laser bakes it into the glass.
¹ Yellow fiber cable only. Typical for armored laser cables (15–20× outer diameter). Source: YH Laser, 2026.
* Damage caused by handling outside these guidelines may not be covered under warranty.
The Apollo 4 is delivered on a single pallet with all components packed and labeled. The next pages list every box on the pallet and what is inside it. Use them as a reference throughout the assembly.
The first step in 4x4 Laser assembly is to install the leveling feet on your leg tubes.
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 108, 306
1.1 Attach a leveling foot to each leg
Gather all black frame tubes on a large work surface and assemble the frame of the 4x4 Laser.
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 117, 120, 309, 402
2.1 Identify the LH and RH lower rail tubes
2.2 Lay out the frame tubes
2.3 Bolt the frame joints together
2.4 Square the frame, then tighten the bolts
First, complete the assembly of the Y-axis bearing block carriages.
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 115, 119, 205, 206, 308, 309
3.1 Assemble the Y-axis bearing block carriages
3.2 Place the Y-axis rails and carriages
3.3 Bolt the Y-axis rails to the stanchions
Complete the Z-axis assembly and mount it to the X-axis carriage.
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 112, 113, 114, 118, 206, 308, 309, 402
4.1 Mount the Z-axis on the X-axis carriage
4.2 Close-up of the gantry mount
4.3 Mount the gantry on the Y-axis carriages
Each Y-axis carriage has two bearing block assemblies, each with two fixed and two adjustable bearing blocks. Adjust them so the bearings are preloaded against the Y-axis rails.
5.1 Set the bearing block preload
5.2 Tighten the gantry bolts in order
Fit the tube caps on the open ends of the frame tubes.
6.1 Fit the tube caps on the frame
Install the Y-axis lead screw bearing mounts.
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 109, 114, 401
7.1 Install the Y-axis bearing mounts
7.2 Install the X-axis lead screw bearing
Install the mounts for the Y-axis stepper motors.
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 110, 114, 203, 307, 404
8.1 Install the Y-axis motor mounts
8.2 Install the Y-axis lead nuts
8.3 Install the X-axis lead nut
Install both of the Y-axis Lead screws.
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 111, 204
9.1 Install the Y-axis lead screws
9.2 Install the X-axis lead screw
Tell the X and Y motors apart before you install them.
The 4x4 Laser uses 3 NEMA-23 closed-loop stepper motors. All 3 motor bodies are identical, so use the cable length to tell them apart:
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 112, 403
10.1 Install the Y-axis motors
Motor Coupler Differentiation
4-Screw Steel Couplers, the installation procedures are the same.
10.2 Install the X-axis motor
Attach the bed side mounts to the frame, then set the cutting bed in place.
YOU WILL NEED FROM THE HARDWARE BOX Fastener bags 104, 116, 125, 202, 206, 305, 309, 310
11.1 Locate the bed and bed side mounts
11.2 Attach the bed side mounts to the frame
11.3 Check the bed mounts are aligned
