NOTE: These assembly instructions are for the LEGACY version of the CrossFire CNC. If you have a CrossFire Machine #15647 or after (located on your gantry tube), please follow the current CrossFire Assembly Instructions.
To the newest CrossFire™ owner:
Thank you for your purchase! We cannot express how grateful we are that you have put your faith and trust in our dedicated company to deliver to you a quality product at an affordable price. Your support helps us keep doing what we are passionate about; putting affordable automated plasma cutting technology into the skilled hands of fabricators, artists, and makers across the globe so that they may bring their ideas to life.
For many of our customers, the CrossFire is their first exposure to both plasma cutting and CNC machinery. We want to re-assure you that we stand behind you and want to do everything we can to make your use of this product as rewarding as it possibly can be. We want you to know that we are always an email or phone call away. We also have an online forum accessible from our website where you can connect with other owner’s to get your questions answered. We know we have done our job well when customers tell us that they can’t believe how such an affordable tool can work so well and be so easy to use; especially when they need it most!
We love hearing from our customers about what they are building with the CrossFire. If you have a cool project that you are proud of, please tell us about it! We love to showcase the amazing work of our customers on our website and social media. Furthermore, we encourage you to share your non-proprietary designs and cutting files with the online community on our website so that others may have the chance to experience your idea come to life on their own machine.
Once again, thank you for putting your faith in Langmuir Systems. We wish you many years of reliable cutting.
Sincerely,
The Langmuir Systems Team
When used correctly, the Langmuir Systems Crossfire CNC Plasma Table will offer you years of safe operation. However, like all other automated and industrial type machinery, there are important safety considerations and precautions that must be followed in order to avoid injury. Study these safety warnings carefully before assembling and using your machine.
Electric shock can cause serious injury or death. This machine requires the use of high voltage electricity to operate. To avoid injury, always adhere to the following precautions:
Fire and explosion can be caused by the airborne sparks and slag igniting a nearby flammable material. Electrical fires can be caused if the machine is assembled or used incorrectly. To avoid injury, always adhere to the following precautions:
Gases and fumes produced during the plasma cutting process can be hazardous to your health. To avoid injury, always adhere to the following precautions:
The plasma cutter produces high intensity ultraviolet and infrared light that can damage your eyes and skin. To avoid injury, always adhere to the following precautions:
Plasma cutting creates airborne sparks and debris that can cause eye injuries. To avoid injury, always adhere to the following precautions:
The plasma cutting process uses extremely high temperatures to cut metal. As a result, the material can be very hot after cutting which can cause burns. To avoid injury, always adhere to the following precautions:
The Langmuir Systems CrossFire comes to you only partially assembled. Therefore, this section serves to provide all of the pertinent information and instructions needed to fully assemble your new machine.
Unbox the CrossFire Machine with an overview of the parts you've received.
Assemble the tubular steel frame of the CrossFire.
Install the upper rail tube and the gantry with stanchion plates.
Install the slat holders and slats if you are not going to install the water table.
If you plan on installing the water table, you can skip this step and follow the Water Table Assembly instead.
Install the X and Y-axis Stepper Motors and Lead Screws.
Install the Torch Mount, Tube Caps, Cable Support Tube, Torch Height Stand-off Shims, and T-Handle Hex Key.
Secure the lead nuts after aligning the machine.
TIP: Before operating your machine, it is important to oil your lead screws to reduce friction as much as possible. We recommend using either multipurpose oil or motor oil. Place a few dabs of oil along the length of the lead screws and cycle the gantry and torch to fully coat.
Install the electronics enclosure and connect the stepper motors.
If you purchased a CNC - CrossFire Compatible Razorweld Plasma cutter (Razorcut 45 CNC or Vipercut 30 CNC) from Langmuir Systems, your plasma cutter is plug and play with your CrossFire CNC system. Use the provided Torch Firing Cable to plug directly into the CNC Port on your Razorweld Cutter.
The CrossFire was designed to be compatible with plasma cutters that are equipped with a hand torch or machine torch. A hand torch enables the operator to start and stop the cutting action by squeezing and releasing the torch trigger. This section contains the instructions for a hand torch.
When installed on the CrossFire, the electronics system must have control over when the torch turns on and off. Providing this control requires splicing into the wires that connect to the trigger so that the CrossFire’s onboard relay can fire the torch when commanded to do so by the CPU.
The purpose of this section to provide the general procedure required to make the wire splices inside of your plasma cutter to facilitate mechanized cutting on the CrossFire. The procedure was designed to be as easy and minimally invasive as possible while preserving your plasma cutter’s ability to be used for hand cutting when not used on the CrossFire. Since there are dozens of plasma cutters on the market, the procedure is intentionally general so that it may be applied to any compatible plasma cutter you select.
Splicing into the torch trigger wires may or may not violate your plasma cutter’s warranty. It is your responsibility to check with your plasma cutter manufacturer regarding the terms of the warranty and whether or not executing the splicing procedure violates those terms. Langmuir Systems will not be held responsible for warranty violations.
Completing the procedure requires opening up the cabinet of your plasma cutter power supply which will expose you to high voltage and high amperage electrical components. It is your responsibility to make sure that all work is done safely and with the power disconnected. If you have any doubts regarding your ability to safely perform this work, we strongly urge you to solicit the services of a professional electrician. Langmuir Systems will not be held responsible for any injury or death resulting from the incorrect or unsafe execution of this procedure.
After the wire splices are made, it is critical to never leave the torch firing cable connected to the CrossFire electronic enclosure when the torch is not installed in the torch mount and ready to cut. If the torch is required for hand cutting duty, it is imperative to first disconnect the torch firing cable before removing the torch. Failure to do so creates the opportunity for the CrossFire electronic system to turn the torch on when the torch is physically in an unsafe location; such as in the presence of volatile or explosive substances. Failure to disconnect the torch firing cable from the electronic enclosure when the torch is not installed can cause serious injury or death. Langmuir Systems will not be held responsible for any injury or death resulting from the lack of adherence to this critical safety requirement.
A test light or a multi-meter with continuity measuring capability is required to complete this procedure. Your plasma cutter may be different than the one shown so you may find that the procedure for your specific plasma cutter may need to differ somewhat.
Find Torch wiring hardware (Bag #14) and your plasma cutter. We'll be using the Razorweld Vipercut 30 in this example.
Unplug your plasma cutter and wait for at least 10 minutes before proceeding in order to provide sufficient time for the internal capacitors to discharge.
Disconnect the torch hose from the plasma cutter power supply.
With the trigger not depressed, use your multimeter to check if there is continuity between any sets of pins. If there is continuity between a set of pins, make note of them.
Use a piece of tape to temporarily depress the torch trigger.
Again check for continuity between sets of pins with your multimeter.
The set of pins that did not have continuity when the trigger was not depressed, but do now, are the trigger wire pins. Make note of their location in the connector.
Make note of the location of the trigger wire pin receivers in the female connector on the plasma cutter.
Remove the cover of your plasma cutter cabinet. Some plasma cutters will require tools to accomplish this. The objective is to gain access to the wires that connect to the torch hose connector mounted to the exterior of your plasma cutter.
Once open, identify the wires inside of the plasma cutter cabinet that correspond to the trigger wire pin receivers in the female connector.
Attach the T-tap connectors to the trigger wires. You may need to use a set of pliers to clamp them onto the wires to ensure that the clasps fully lock.
Langmuir Systems provides 3 different sizes of T-taps for different gauge wires. Please use the appropriately sized tap for your wire: Not too wide of a slot so it doesn't cut the wire insulation and not too tight where you can't snap it on.
Once snapped into place, work the connector back and forth a few times (half turns) to ensure the insulation is cut and the metal is exposed to the connector.
Locate the torch firing cable that was provided with your machine and connect the blade connectors to the T-Tap connectors.
It does not matter which blade connector gets plugged into which T-tap connector. The polarity and wire coloring is not important.
Plug the torch hose back into the plasma cutter.
With the torch trigger depressed, check the continuity between the two bare ends of the torch fire cable. If you spliced into the correct wires, there should be continuity. If not, go back and verify that the correct wires were identified in Step 3.
Release the trigger. Verify that there is no longer continuity between the two bare ends of the torch fire cable.
Reinstall the cover on the plasma cutter cabinet with the torch fire cable exiting the cabinet in a convenient location. Make sure that there are no sharp edges that could damage the torch fire wire insulation. Add additional abrasion protection as needed.
Plug the male end of the torch fire cable into the 'Torch On/Off' jack in the electronics enclosure.
As instructed in our cutting tutorials, plug in the plasma cutter with torch installed only when the torch is installed into the Torch Mount for firing safety.
First, install the Y-Axis motor.
Once your machine is fully assembled, continue on to our software tutorials to learn the basics of CAD/CAM and start cutting!
The CrossFire water table is designed for use with cutters up to 45 Amps. For use with cutters over 45 Amps, we recommend using additional insulating material to prevent damage to the tray.
Use these installation instructions to assemble and install your water table.
We have phased out Aluminum Water Tables in favor of Stainless Steel in order to eliminate possible corrosion. Zinc Anodes are no longer necessary. If you have an older Aluminum Water Table, we do not recommend using a rust inhibiting product as this will corrode the aluminum faster than using only water. Check and replace your zinc anodes as they wear out.
Note: Gantry assembly hidden from view.
Installation Steps:
Use these installation instructions to assemble and install your laptop stand.
Installation Steps:
All Langmuir Systems products are covered by a 12 month limited warranty on hardware and 6 month limited warranty on electronics. The terms of the warranty are listed below:
All products sold directly by Langmuir Systems are eligible for return and refund. The terms of the return and refund policy are listed below:
