Mill with CutControl
Last updated: August 30, 2022
Introduction
CutControl is a proprietary controller software made by Langmuir Systems to operate the MR-1 CNC Mill. The software was designed with several key features specific to milling while offering an easy-to-use interface.
CutControl software is used to connect your computer's USB port to the MR-1 CNC Electronics unit for controlling the machine and for running milling programs. The below User Guide explains the features of CutControl and how to setup and configure this software for use with your MR-1. We highly recommend reading and watching this User Guide in its entirety before operating your machine and software.
We are continually updating this guide with more information as documentation becomes available.
Installing CutControl Software
The latest version of CutControl can be downloaded from our website at http://www.langmuirsystems.com/downloads.
Make sure your computer meets the following system requirements.
System Requirements
  • Operating System: Windows 7+ / MacOS 10.13+
  • Minimum Processor Speed: 1.6 Ghz, 64 bit
  • Minimum RAM: 4 GB
  • Graphics: OpenGL 3.0+ compatible
  • Available Disk Space: 150 MB
  • Ports: One USB 2.0 (Standard Type A)
After downloading the CutControl installer from our website, follow the onscreen installation prompts to correctly install the software on your computer. You will not need to restart your computer after installation. Be sure to note the folder on your computer where the software will be installed; we recommend creating a Desktop shortcut for quick access.
Windows Defender for Windows 10
Note: If you are installing CutControl on Windows 10, you will likely encounter the Windows Defender dialog shown below. The below images reference FireControl but the same dialog will occur with the CutControl installer as well.
installing CutControl Windows 10
To continue installing CutControl, please select the 'More Info' link beneath the text. Then click on the 'Run Anyway' button at the bottom of the box.
installing CutControl More Info
General Overview
We cover an overview of the CutControl interface with a focus on the CutControl Visualizer. We'll run you through the basic functions so that you can hit the ground running.
Jogging
We cover jogging on the MR-1 CNC Gantry Mill with CutControl. With this video you too can master movement of the spindle and avoid any nasty crashes that might occur to the untrained operator.
Program Loading
We cover how to load programs into CutControl. We'll explain all the different ways to load programs on MR-1 and how to make sure that they're going to run smoothly.
Smart Programming with Google Drive
How to use Google Drive to quickly access programs across computers and collaborate with others.
Keyboard Shortcuts
CutControl has several built-in keyboard shortcuts which make it easier to operate, especially if you have a wireless keyboard that can be used as a pendant for jogging. These shortcuts can be accessed from the CutControl help menu for quick access and they are also listed below.
  • Jog X+: Right Arrow Key
  • Jog X-: Left Arrow Key
  • Jog Y+: Up Arrow Key
  • Jog Y-: Down Arrow Key
  • Jog Z+: Page Up Key
  • Jog Z-: Page Down Key
  • Toggle Nudge Jog: Tab Key
  • Start Program: ALT + R
  • Pause Program: Space Bar
  • Stop Program: ALT + S
  • Zoom in Visualizer: Mouse Scroll Up
  • Zoom out Visualizer: Mouse Scroll Down
Updating CutControl
To check your current version of CutControl, click the ‘Help’ Menu and then ‘Check for Updates’. Your version of CutControl will be listed along with a link to our Downloads page to check if a newer version of CutControl is available for installation.
