VIP Early Access
Members only · Private link
Apollo 4
VIP Access
You're one of the few who get in before the public. For one hour, the Apollo 4 is yours to claim, in full or with a deposit, before anyone else can.
  • Buy in full, VIP only. The public can only place deposits.
  • Limited units, delivered by the end of the year
  • FREE PC Kit & Gold Warranty included for orders in the first 24 hours - $1,500 Value
39 of 50 VIP paid-in-full units left
Your early access opens in
--Days
--Hours
--Min
--Sec
Claim Your Apollo 4
Public opens at 12 PM CT. Paid-in-full units are limited and won't be offered to the public.
Apollo 4
Compact 4' x 4' Fiber Laser for Metal Fabrication
Not every shop has room for a full-size laser. The Apollo 4 packs the same industrial fiber laser cutting as the Apollo into a compact, fully enclosed 4' x 4' machine built for small metal fabrication and automotive shops. Its 1.5kW Max Photonics source cuts steel up to 1/2" thick, plus stainless, aluminum, and brass, with clean edges. A material pass-through lets longer stock extend through the front or back of the enclosure, so you can cut larger parts without moving up to a bigger machine. Like Apollo, it runs LaserControl software and is supported by our team in Texas.
Need full-sheet capacity? Check out the Apollo 4' x 8' CNC Fiber Laser. Cutting thicker plate on a budget? The CrossFire PRO MAX 4' x 4' CNC Plasma Table cuts steel up to 1" thick. Not sure about the different capabilities between laser and plasma? Learn more about different cutting technologies.
The Fiber Laser your shop has room for
Full-scale performance in a 4' x 4' platform
BIG CAPABILITY. SMALLER FOOTPRINT.
Apollo 4 delivers a full 48" × 48" cutting area in a compact, fully enclosed fiber laser system. Get the speed, precision, and cut quality of industrial fiber laser technology without dedicating the floor space required by a full-size machine.
EASY ACCESS FROM EVERY ANGLE
Loading material, retrieving parts, and accessing the work area shouldn’t be a chore. Apollo 4’s removable enclosure doors give you easy access when you need it, while integrated safety interlocks ensure the enclosure is secured before cutting begins.
MATERIAL PASS-THROUGH
Apollo 4 provides an innovative enclosure system that allows you to load and handle a 4' × 8' sheet of material giving you more flexibility when you need it. Material pass-through feature allows larger stock to extend through the enclosure (front and/or back), giving you more options without moving up to a larger machine.
INDUSTRIAL-GRADE HARDWARE
Every aspect of Apollo has industrial capability built in for performance and reliability. Quality components such as the Max Photonics source, the RayTools heads, and a 3-axis full closed-loop drive system.
LaserCAM Built In
Bring your dxf file right to the machine, on USB, shared drive, or Network location. The LaserCAM software allows you to work seamlessly with LaserCONTROL, a professional feature found in machines many times more expensive.
LaserCONTROL = Total Control
If you have used any of our other products, such as FireControl, then you will already be familiar with LaserControl. It has a full featured interface that allows you to adjust every parameter, but it was built with simplicity and is intuitive to use. LaserControl is both friendly to use, and familiar to ten’s of thousands of users already.
SUPPORTED HERE IN TEXAS
Engineered in Texas. Assembled in Texas. Supported in Texas. Our team is here when you need help. We offer parts, fast shipping, and technical support via phone and email when you need it. You can purchase consumables, get warranty support, or talk to a technician about issues you’re experiencing. Call or email, we’re here to help.
1 / 1
VIP Exclusive
Choose Your Apollo 4
Paid-in-full is offered to VIPs only, and units are limited across all three packages. Prefer to hold your place? Reserve with a deposit.
COMPARE APOLLO 4 PACKAGES
EQUIPMENT & OPTIONS
PRICE
WELL EQUIPPED
$11,995
ADVANCED
$14,495
SAVE $413
STANDARD EQUIPMENT
Apollo 4 Fiber Laser
48 × 48 cutting area.
STANDARD
STANDARD
STANDARD
Laser Source
Max Photonics 1500X, Professional Grade.
STANDARD
STANDARD
STANDARD
Jog Pendant and Magnetic Holder
Wireless jog pendant for easy movement of the laser head (when unpowered).
STANDARD
STANDARD
STANDARD
Focus Head
BT-220 manual focus head, professional quality, include amplifier for Auto Height Control.
STANDARD
STANDARD
UPGRADED
AutoFocus Head by RayTools
Chiller
S&A CWFL-1500, standard.
STANDARD
STANDARD
UPGRADED
Pro-Series CWFL-1500
Enclosure Doors
Standard doors, no windows.
STANDARD
UPGRADED
Door w/Laser Safety Glass
UPGRADED
Assist Gas System
Nitrogen or Compressed Air compatible.
STANDARD
UPGRADED
Compatible with Oxygen Assist Gas for clean cuts
UPGRADED
OPTIONS
PC and 21.5" Touchscreen Kit
PC and 21.5" touchscreen for machine control.
$749
NOT AVAILABLE
Included FREE if you order today
INCLUDED
INCLUDED
Camera, Lighting and Monitor System
Camera, Lighting, and Monitor System
Mount a second monitor to Apollo and plug in the Camera to have a birds-eye view of the status of the action inside.
$499
NOT AVAILABLE
INCLUDED
INCLUDED
Gas/Chiller Hook-Up Kit
100' of tubing, O2 and N2 Regulators, flashback arrestor, and various Push-to-Connect fittings so you can hook up gas, chiller, and air.
$399
NOT AVAILABLE
INCLUDED
INCLUDED
Oxygen Assist Gas System
Adds oxygen assist on top of the standard Nitrogen / Compressed Air system.
$149
NOT AVAILABLE
INCLUDED
INCLUDED
Laser Head Consumables Kit
Contains 7 nozzle types for various material types and thickness, 3 Protective consumable lenses.
$79
NOT AVAILABLE
INCLUDED
INCLUDED
Door with Laser Safety Glass (Qty 2)
Have the ability to peer inside the upper enclosure with safety rated glass.
$999
NOT AVAILABLE
INCLUDED
INCLUDED
Fume Extraction Adapter Kit
6" Tube that gives users the ability to hook their own suction device or fan.
$39
NOT AVAILABLE
INCLUDED
INCLUDED
Quicker tuning, easily switch materials and thickness, and has longer consumables life.
$1999
NOT AVAILABLE
NOT AVAILABLE
INCLUDED
Pro-Series Chiller CWFL-1500 by S&A
Pro-Series comes with upgraded components, improved filtration, larger heat exchangers, low water alarm, water pressure gage, and more.
$1999
NOT AVAILABLE
NOT AVAILABLE
INCLUDED
STANDARD EQUIPMENT
WELL EQUIPPED: Standard
ADVANCED: Standard
PRO: Standard
Laser Source
ADVANCED: Standard
PRO: Standard
ADVANCED: Standard
PRO: Standard
Focus Head
ADVANCED: Standard
PRO: Upgraded
Chiller
ADVANCED: Standard
PRO: Upgraded
Enclosure Doors
ADVANCED: Upgraded
PRO: Upgraded
Assist Gas System
ADVANCED: Upgraded
PRO: Upgraded
OPTIONS
PC and 21.5" Touchscreen Kit $749
WELL EQUIPPED: N/A
ADVANCED: Included
PRO: Included
Camera, Lighting, and Monitor System $499
WELL EQUIPPED: N/A
ADVANCED: Included
PRO: Included
Gas/Chiller Hook-Up Kit $399
WELL EQUIPPED: N/A
ADVANCED: Included
PRO: Included
Oxygen Assist Gas System $149
WELL EQUIPPED: N/A
ADVANCED: Included
PRO: Included
Laser Head Consumables Kit $79
WELL EQUIPPED: N/A
ADVANCED: Included
PRO: Included
Door with Laser Safety Glass (Qty 2) $999
WELL EQUIPPED: N/A
ADVANCED: Included
PRO: Included
Fume Extraction Adapter Kit $39
WELL EQUIPPED: N/A
ADVANCED: Included
PRO: Included
AutoFocus Head by RayTools $1999
WELL EQUIPPED: N/A
ADVANCED: N/A
PRO: Included
Pro-Series Chiller CWFL-1500 by S&A $1999
WELL EQUIPPED: N/A
ADVANCED: N/A
PRO: Included
STANDARD EQUIPMENT
INCLUDED IN PACKAGE
UPGRADED IN PACKAGE
OPTIONAL — ADD AT LISTED PRICE
NOT AVAILABLE
Apollo 4 Specifications
Apollo 4
SPECIFICATION
DETAIL
Cutting Area:
48" × 48" (4' x 4')
Laser Power:
1500W Fiber Laser by max Photonics
Shop Power:
Laser System – 240V, 25A
Chiller – 240V, 20A
Cooling
Water-Cooled, CWFL-1500 by S&A
Exhaust:
6” exhaust port
Z-Axis Clearance
2.25"
Maximum Jog Speed
400 IPM
Safety:
  • Enclosure with removable panels with door switches
  • Optional Camera system
  • Optional Doors with Glass
Software and Controls
  • LaserControl Software
  • 32-Bit integrated Electronics
  • Optional Touchscreen and PC
Max Material Capability:
Steel - 1/2"
Stainless Steel - 7/32”
Aluminum - 3/16”
Brass - 3/16”
Positioning Accuracy:
±0.002” per 12”, 0.0005” index
External Dimensions:
75" W x 60" H x 75" L
Travel Limits:
48" X, 48" Y, 3" Z
Subscribe To Our Newsletter
Subscribe to get special offers, free giveaways, and updates about new products.
* indicates required
Apollo 4 CNC Fiber Laser FAQ
What is the Apollo 4 CNC Fiber Laser and what is it used for?
The Apollo 4 CNC Fiber Laser is a precision CNC-controlled sheet metal cutting system that uses a 1.5kW fiber laser to deliver fast, accurate cuts with minimal post-processing. Its compact 48" × 48" cutting area brings industrial-grade fiber laser capability to shops where floor space matters.
What software is used for the Apollo 4 CNC Fiber Laser?
The Apollo 4 CNC Fiber Laser uses our in-house engineered LaserControl software. LaserControl shares the familiar look and workflow of other Langmuir Systems software such as FireControl and CutControl, while providing the controls and parameters required specifically for fiber laser cutting.
What is the cutting area of the Apollo 4 CNC Fiber Laser?
The Apollo 4 CNC Fiber Laser features a full 48" × 48" cutting area. An integrated material pass-through, that can be positioned on the front or back of the machine, allows longer stock to extend through the enclosure, giving you additional flexibility when working with material larger than the machine’s cutting envelope.
Can Apollo 4 cut material longer than 48"?
Yes. Apollo 4 features material pass-through that can be positioned on the front or back of the machine that allows stock longer than 48" to extend through the enclosure. The machine’s active cutting area remains 48" × 48", so the pass-through provides greater flexibility for loading and positioning longer material without increasing the machine’s cutting envelope.
What is included when I purchase the Apollo 4 CNC Fiber Laser?
The Apollo 4 comes equipped with the 1.5kW fiber laser source, laser cutting head, water chiller and fully enclosed machine system. Additional accessories and upgrades are available depending on your configuration.
Oxygen, nitrogen, or suitable compressed shop air will also be required depending on the material and cutting process being used.
What safety features are available on the Apollo 4 CNC Fiber Laser?
Apollo 4 features an enclosed cutting area with removable access doors and integrated safety interlocks that prevent the laser from firing unless the enclosure is properly secured. The removable doors provide easy access for loading material, setup, maintenance, and part retrieval.
Optional laser-safe viewing glass provides visibility into the cutting area while the enclosure remains closed. Proper laser-rated PPE and all applicable safety procedures including wearing laser safety glasses should always be followed when operating the system.
I want an Apollo 4 CNC Fiber Laser but I don’t have any CNC laser cutting experience. Is it still a good choice for me?
Yes. Apollo 4 uses our intuitive LaserControl software and is supported by setup guides, tutorials, documentation, and our dedicated support team. Even if fiber laser cutting is new to you, these resources are designed to help you get familiar with the machine and cutting workflow quickly.
What is the maximum material thickness that I can cut on the Apollo 4 CNC Fiber Laser?
The Apollo 4 CNC Fiber Laser can cut carbon steel up to 1/2" thick, depending on material conditions, assist gas, cut parameters, and desired cut quality.
Can I cut other materials on the Apollo 4 CNC Fiber Laser?
Yes. The Apollo 4 CNC Fiber Laser can cut the following:
  1. Up to ½” Carbon Steel
  2. Up to 7/32” Stainless Steel
  3. Up to 3/16” Aluminum and Brass
Can I finance the purchase of Apollo 4?
Yes, we are partnered with Geneva Capital and Affirm for financing needs of our customers. While you will need to provide the $500 deposit via credit card to initially reserve a machine, financing for the balance can be established via Geneva Capital or Affirm right before your machine ships.
How does Apollo 4 ship and what does it cost?
The Apollo 4 CNC Fiber Laser ships via freight/LTL from our facility in Conroe, Texas. Shipping cost varies based on your location. Customers will need to supply a forklift capable of lifting 1000lb and has extended forks (6ft minimum length forks).
Can I pick up my Apollo 4 in-person to avoid shipping costs?
Yes, local pickup orders from our facility in Conroe, Texas can be scheduled to avoid shipping fees. A suitable vehicle with at least 70” of bed width is required to safely transport Apollo 4. The loading of the machine will be completed by Langmuir Systems' personnel with our equipment. All strapping and securing equipment shall be provided by you, the customer, with no exception. You must make an appointment for pickup by sending an email to [email protected] once your machine is prepared and your balance is paid.
Is lift gate service available upon delivery?
Yes. The Apollo 4 CNC Fiber Laser ships via freight, liftgate service is generally available from ABF, our freight partner.
Do you ship Apollo 4 Internationally?
No. The Apollo 4 CNC Fiber Laser ships to the lower 48 states only. Please contact a freight broker for international shipments.
Are accessories and options more affordable if purchased at the same time as Apollo 4?
We recommend ordering your desired Apollo 4 accessories and upgrades with the machine whenever possible. Combining accessories with the initial machine shipment can reduce additional freight costs and ensures your preferred configuration is ready from the start.
How long does it take to assemble Apollo 4?
Apollo 4 comes as a kit and requires user assembly. Assembly time varies with skill level and selected options and accessories. We expect the average assembly to require 20-40 hours to complete depending on users skill. We recommend the use of a suitable hoist or multiple assemblers for ease of installation with the upper enclosure.
Now that my Apollo 4 is assembled and operable, what’s next?
Start by reviewing the Apollo 4 Quick Start Guide, safety information, and recommended maintenance procedures. From there, familiarize yourself with LaserControl, machine positioning, assist-gas settings, and material-specific cut parameters before beginning production work.
Are replacement parts available?
All machine components are offered as replaceable items for purchase if stock is available. Send us an email at [email protected] with your needs and we will prepare you an invoice.
Can Apollo 4 be run on 120V power?
No. Apollo needs two separate, dedicated 240VAC single-phase circuits:
• Laser System – 240VAC, single phase, dedicated 25A breaker
• Chiller – 240VAC, single phase, dedicated 20A breaker
What is the warranty on the Apollo 4 CNC Fiber Laser?
What is the return and Refund Policy for the Apollo 4 CNC Fiber Laser?
More questions?
Please reach out to our support team via our Apollo 4 Support Page.
